So i intend on picking up an f-90bt in a short while (once a few things clear up). I had a d3 in my last vehicle. In my new vehicle i will install an amplifier which uses the pre-outs from the avic.
In the name of efficiency and customizing the cable length and keeping the harnesses as compact as possible behind the dash, i want to solder the pre amp outputs from the avic to the cables that run to the amplifier.
Basically trim off the rca jacks from the avic and the cables i will use and solder the two together, heat shrink and then tape up, just like every other wire back there.
I know it can be done and i know that the sound/efficiency probably wont improve enough to hear and it will be more permanent that just connecting the two, but is there any downside besides the few minutes it will take and the permanency? The main reason is so that i don't have 10 feet of cable lying around waiting to pick up noise from every possible source.
I intend to leave the connector on the amplifier end, as i do not intend on soldering near a nice amplifier, but the avic harness lends itself to these kinds of mods.
