No longer have TTS voices as an option... they're missing!
By unrequited · Jun 25, 2008in Problems/Troubleshooting💬 11 posts👁️ 3,638 views
Posted Jun 25, 2008 · 00:55 UTC#1
When I first plugged in and turned on my F90BT, I selected Jason (English non-TTS) but at least saw the TTS voice as an option. I have no option to select any TTS voice (English or otherwise) and only have 3 options:
English (Jason)
Spanish (MEX dunno the name)
French (dunno the name)
where'd my TTS options go?
(I know the TTS chick has a problem saying comma all the time, but still...)
Posted Jun 26, 2008 · 12:32 UTC#2
can anybody give me a hand?
Posted Jun 26, 2008 · 12:58 UTC#3
Have you tried resetting the unit to factory settings?
Posted Jun 26, 2008 · 13:06 UTC#4
With the reset button? A couple times. I don't have the manual with me and pioneer's website seems to be down for me so I dunno if this is what you're talking about.
Posted Jun 26, 2008 · 15:39 UTC#5
if you goto i think system setting theres a button that says restore factory settings
Posted Jul 01, 2008 · 03:59 UTC#6
Finally got back from business trip. Resetting factory settings doesn't work. Neither does turning off power and pushing reset button, or turning power on and pushing reset button.
Does anybody know a way to clear the entire system back to first-time use? I looked through the manual's 3 ways and none of them remove my boot screen so none of them are truly clearing everything out.
Posted Jul 22, 2008 · 05:21 UTC#7
With latest update, I still have NO TTS choices, just three choices, Jason, Esperanza, and some french choice (forget the name).
Posted Jul 22, 2008 · 05:52 UTC#8
it's weird because in "test mode" under:
\My Flash Disk\APL2\iGo\CONTENT\VOICE\
I have 6 files:
voice_eng-us-m1.zip
voice_esp-mex-f1.zip
voice_fra-f31.zip
these are the only choices I have for voice...
I also have these three which are the same as the update's \MiTACAP\APL2\iGo\content\voice folder:
voice_tts-nua-eng-us-f1.zip
voice_tts-nua-esp-f1.zip
voice_tts-nua-fra-can-f1.zip
I'm assuming these are the new TTS voices that I never had as an option, and still don't. They're in the folder, they should be read and it should be available to me as an option, but it's not.
Could somebody please boot into test mode and let me know if I have all of the voice files in this directory?
Just go into:
and type up which ones you have. Thanks.
Posted Jul 22, 2008 · 11:49 UTC#9
Maybe you completed the first step of the firmware update, but didn't finish all the steps?
Make sure you follow the steps to the update, specifically steps 7-11. Looking through the folders you copy over in steps 7 and 8, it looks like the TTS voices are there.
I have the voices, although I had to go to languages and select the guy voice then select Samantha to get it working.
Franco
Posted Jul 22, 2008 · 20:02 UTC#10
Yeah, I specifically made mention of the files used in the last steps... and you can't boot into test mode without using those steps so...
Posted Jul 23, 2008 · 13:28 UTC#11
All my TTS voices are still there after the update.
