D3 and Sirius (yes, HiFi I did a search)
By jaedee · Jun 25, 2008in Problems/Troubleshooting💬 4 posts👁️ 935 views
Posted Jun 25, 2008 · 15:26 UTC#1
Got in my truck this morning and my Sirius won't change channels. I can directly input a channel but when I hit enter it does not change. I am stuck on Radio Disney (my kids) but have no sound when in Sirius mode. Everything else works except the Sirius. I found a smiliar topic with the "search" function (for HiFi) but nobody answered the question.
Posted Jun 25, 2008 · 16:22 UTC#2
:? I almost decided to ignore this topic out of spite for the title. But then ended up being too curious to do so.
Do you have any other IP-BUS components hooked up? Try swapping the cable from the other device as the one hooked to the Sirius module may have gone bad.
Also, try disconnecting the power from the Sirius module to reset it, then plug it back in and try it. You'll lose all your presets, but at this point they're useless anyway so it's worth a try.
Posted Jun 26, 2008 · 14:48 UTC#3
I knew I could sucker you in. Thanks, I will try swapping between the bt and sirius modules. It was stange because when I shut off my truck, everything as working and then I got in my truck and it didnt work.
Posted Jun 27, 2008 · 14:47 UTC#4
Now I'm seriously confused. I jumped in my truck after work, switched to Sirius and the bastard works perfectly. I didn't do anything from when I parked my truck to got back in it. Didn't even move it. I'm starting to think my frickin' Avic is messing with me. Guess I will worry more about if it happens again.
