Blackberry Curve 8310 Help
By bwolfe · Jun 25, 2008in General💬 10 posts👁️ 2,128 views
Posted Jun 25, 2008 · 20:41 UTC#1
I didn't want to pollute an already in progress topic, so I did a new one.
Here is the dilemma, I have the F900BT and the bluetooth works with a little static, OK maybe a little more than a little.
Now I want to transfer my phonebook from my BB Curve 8310 and for the life of me I can't figure how to send them. The F900BT sits and waits for the transfer, but I can't figure out how to initiate a transfer from my phone to my radio.
Anyone out there with the 8310 who has done this?
Thanks.
Posted Jun 25, 2008 · 21:48 UTC#2
I figured it out. Under -> Options -> Bluetooth.
You need to be connected and then an option shows up to transfer phonebook.
:oops:
Posted Jul 01, 2008 · 23:22 UTC#3
Anyone else have one of these?
When I transfer the phonebook it only sends over 6 of the 80 contacts I have. I have tried it four times and the same results. Funny thing is, its the same 6 contacts each time.
Help? :lol:
Posted Jul 02, 2008 · 22:51 UTC#4
I can't seem to get my AT&T Blackberry 8310 to connect to my Avic-F90BT...
What am I doing wrong here? They are both searching for connection but can't find each other. My brothers iPhone worked right away...
Please advise
Thanks,
James
Posted Jul 07, 2008 · 15:44 UTC#5
I have the same problem, however mine will connect for a minute then disconnect on it's own?? Any thoughts
Posted Jul 07, 2008 · 17:26 UTC#6
Mine does that too, erractically. After a while it will usually connect but gives the "connection to pioneer navi failed" a few times first.
Posted Jul 07, 2008 · 18:06 UTC#7
Mine will stay connected, it just will only move over a small amount of contacts. So it kind of sucks. On my d3, I had no problems whatsoever.
Posted Jul 15, 2008 · 20:59 UTC#8
same boat..
Posted Jul 16, 2008 · 15:02 UTC#9
I have the 8330 from Sprint.
Was able to transfer over all my contacts BUT...can't dial!
I just found this out.
I can receive calls with no issues and speak with no static but dialing is a different issue. Maybe I should try to reset it.
But all I did was option->bluetooth->let others find my device->ok
Then on the navi phone settings and connection.
After the phone connected you can just transfer...
at least thats what i did...
Posted Jul 16, 2008 · 16:14 UTC#10
Hmm I also have the Sprint 8330, and while it takes a long time to connect, I am pretty certain I was able to make calls via my phone book. I think it transferred all of them, but did not double check.
Its moot for me as the call quality is so poor for the remote party that I have turned it off.
They all say I am in a wind tunnel. I have literally turned the AC off, and held the mic in my hand, moving it around the cabin and trying different spots - as close as 12" from my face, to no avail.
