Hi Folks
I know the F700bt does not support video from dvd's but can I still play videos that are stored on my ipod video?
Thanks.
Hi Folks
Thanks.
It will play videos off of CD's, ipod, SD cards, and USB drives.
Thank you sir.
not tryin to be a smartass or give that impression, but isnt a cd with movies on it just a dvd? whats the difference?
Just the amount of available space.
Would the ipod video cable (rca) be required or would the video signal be transported via the CD-IU230V?
thanks.
The CD-IU230V is the ipod video cable. It's all you need. It transports data to the unit through the USB port and audio and video to it through it's RCA connectors.Would the ipod video cable (rca) be required or would the video signal be transported via the CD-IU230V?
thanks.
Video from an USB drive? Sure?
http://www.avic411.com/forum/viewtopic.php?t=15191
They told me that USB does not deliver Video, so USB drives only play music... ![]()
notsure about the whole usb thing but CD and DVD are two completely seperate things. They use different compression, different lasers(in some cases), and different disks.
Skoos:
Yes, it will play videos. I've done it myself as a test. Take a USB thumb drive and put some mpeg videos on it. It will play them the same way the SD card will.
If you read the whole topic you linked to there you'd know that.
Phlame217:
Yes, they use different lasers and compression methods. But in simplest terms, a video file on a CD is just the same as a video file on a DVD, except you can't fit as much on to it.
Skoos:Yes, it will play videos. I've done it myself as a test. Take a USB thumb drive and put some mpeg videos on it. It will play them the same way the SD card will.
Phlame217:
WOW!!! Amazing!
I was afraid of buying ipods, because I don't really like the iTunes. But now, I don't even need it. Yeah. ![]()
How about quality and response-times? I thought that playing Video files from the USB HDD might have better quality than from the Ipod (because Ipod is composite)
Could someone please upload two images for me about the same video (first showing video from the Ipod and second from the USB drive)?
mp4 is actually a decent quality on an iPod but since the player can read Divx from a cd and therefore most likely a usb drive, the usb drive will be much better. As for regular mpeg, there wouldnt be too much of a difference.
It WILL NOT play dixv, xvid, avi files off the usb or sd ports. Only from the CD or DVD drive. The usb and sd slots only play mpeg4 or wmv videos. It's in the owner's manual at the end in the specifications section.
DVD drive (AVIC-F900BT and AVIC-F90BT)System ..........................................DVD-Video, CD, MP3, WMA,
AAC, DivX system
Usable discs ..............................DVD-Video, CD, MP3, WMA,
AAC, DivX
Region number ........................ 1
Signal format:
Sampling frequency ..... 44.1 kHz/48 kHz/96 kHz
Number of quantization bits
........................................... 16 bit/20 bit/24 bit; linear
Frequency response ............... 5Hz to 44 000 Hz (with DVD,
at sampling frequency
96 kHz)
Signal-to-noise ratio ............... 97 dB (1 kHz) (IHF-A network)
(CD: 96 dB (1 kHz) (IHF-A
network))
Dynamic range ......................... 95 dB (1 kHz) (CD: 94 dB
(1 kHz))
Distortion ..................................... 0.008% (1 kHz)
Output level:
Video .................................... 1.0 Vp-p/75W (±0.2 V)
Audio ................................... 1.0 V (1 kHz, 0 dB)
Number of channels .............. 2 (stereo)
MP3 decoding format ...........MPEG-1 & 2 Audio Layer 3
WMA decoding format ......... Ver.9.0 L3
AAC decoding format ............MPEG-4 AAC (only encoded
by iTunes):
.m4a
DivX decoding format ............Home Theater Ver.3.11,
Ver.4.X, Ver.5.X, Ver.6.X :
.avi, .divx
CD drive (AVIC-F700BT and AVIC-F7010BT)
System .......................................... CD, MP3, WMA, AAC system
Usable discs .............................. CD, MP3, WMA, AAC
Signal-to-noise ratio ............... 94 dB (1 kHz) (IHF-A network)
WMA decoding format ......... Ver.7,7.1,8,9,10 (2 ch audio)
(Windows Media Player)
AAC decoding format ............MPEG-4 AAC (iTunes encoded
only)
WAVE SIGNAL FORMAT ...... Linear-PCM, MS ADPCM
(Non Compressed)
USB
USB standard spec. ...............USB 2.0 High Speed
Max current supply ................. 500mA
Max capacity memory ........... 2 GB
File system .................................. FAT16, FAT32
USB class ....................................Mass storage class
Decoding format ......................MP3/WMA/AAC/WAVE/
MPEG4
SD
Compatible physical format
..................................................... Version 2.00
Max capacity memory ........... 8 GB
MPEG4
Now that I look closer, it says the CD drive in the 700 units won't play video at all, just audio. So putting divx movies on a CD won't work... or at least that's what the manual says.
So for the 700's, the ONLY video source is ipod, usb, and sd card. And ALL 3 basically use the same file type, which is MP4.
USB drive with max 2GB storage? Pleah! I wanted to use my 250GB USB2.0 WD Passport... that sux. ![]()
max sd card is only 2gb that will work??
You can still try it and see if it works. The manual says the SD card will only go up to 8GB, but it will go higher than that, so there's a chance it's the same way with the USB. Just plug it in and see what happens. It's not like you've got anything to lose by trying.
The manual says the biggest SD card that will work is 8GB. But (although it hasn't been confirmed that I can remember) the 16GB and 32GB cards are also compatible if you can afford them. It's just at the time that the manual/unit was being produced, the largest consumer available SD cards were 8GB so that's what they set the cap at.
My 4GB SDHC card works fine. The unit will play XVID from the SD slot, although certain (lower) bitrates work better than others. I encoded a movie to 700MB and it played fine. The same movie encoded to 2GB had a slow framerate and a/v sync issues.
i tried usb/sd mp4 but never gets full screen, any idea? thanks
download the manual from pioneer i think there is something on this in there
