Bluetooth and Motorola RIZR Z3
By marichris · Jun 27, 2008in Problems/Troubleshooting💬 3 posts👁️ 859 views
Posted Jun 27, 2008 · 06:57 UTC#1
Why is it that I can't register my phone in my bluetooth, it does acknowledge that it is motorola rizr, I did tried to call already using the bluetooth and it did works fine, but I can't send my phonebook even tried to put in manually the numbers, it does have only some numbers that it acknowledge(usually business #) but not residence or cellphones, will it be the bluetooth unit that does have the problem?
Posted Jun 27, 2008 · 18:03 UTC#2
I'm having a similar problem. I can't transfer any numbers from my phonebook and can't figure out how to even manually build a phonebook. I was able to register my phone and can input numbers for the presets, but can't put a name with those numbers either. Any ideas?
Posted Jul 04, 2008 · 17:52 UTC#3
I also had a similar problem. My bluetooth worked fine until one day it cannot connect. I never bothered transferring my phonebook or anything, but only about a month it stopped working
