Very weak am/fm reception after F700BT install
By kimbo · Jun 28, 2008in General💬 11 posts👁️ 2,690 views
Posted Jun 28, 2008 · 17:08 UTC#1
I live 50 miles north of San Francisco and I can barely receive any of the am stations that should be loud and clear. I Double checked antenna connection. I have Sirius connected and that is fine. Unit is installed in 08 Toyota Yaris. Any ideas before I open up the dash again? Thanks!
Posted Jun 28, 2008 · 18:02 UTC#2
I am in Memphis and I am having the same problem with my 900BT on 3 FM stations. I havent even put it on AM yet. They were loud and clear on my stock radio but now there is a very weak signal if I pick them up at all.
Posted Jun 28, 2008 · 19:48 UTC#3
More than likely your cars come with an amplified antenna. So you need to install an adapter so you can connect the power antenna lead to your antenna wire
Posted Jun 29, 2008 · 01:07 UTC#4
Yep you're right! I did'nt hook up the blue wires (duh). All is well now. I hope this helps roadking1733. Thanks!
Posted Jun 29, 2008 · 16:54 UTC#5
To be honest its in my wifes Jeep so I dont have to hear it every day. I am going to make her struggle through it for a while because I dont want to pull the dash off again. I mean between a flash drive full of music and sirius, who needs regular radio
Posted Jul 01, 2008 · 16:36 UTC#6
I am having the same issue in my 07 Siverado.
What do you connect the blue wire to?
Posted Jul 02, 2008 · 02:09 UTC#7
There is a blue wire on the AVIC harness labled "power antenna" and blue wire on harness adapter for my car model (Toyota) marked the same. Just connect them and you should be good to go if you have an amplified antenna. I assumed "power antenna" refered to an antenna that raises and lowers when turning the power on or off so I ignored the connection (my bad). Hope that helps.
Posted Jul 02, 2008 · 10:23 UTC#8
2008 Silverado with great FM and very poor AM reception. Does the antenna wire apply here?
Posted Jul 02, 2008 · 10:34 UTC#9
Same here...good FM poor AM. I wish XM and Sirius would merge already so I can get baseball. Then the AM issue would be moot for me
Posted Jul 03, 2008 · 00:41 UTC#10
My guess is yes. FM is higher frequency than AM and may more easily pass through an amplified antenna that is not powered up (you know how when in a steel or concrete building FM reception is fine and AM sucks or is totally gone). I am not an electronics tech but I was a radar tech in the navy and I did learn a little about freq wave forms. For what it's worth.
Posted Jul 07, 2008 · 03:25 UTC#11
Fixed my reception issues. I had a faulty antenna adapter.
I now have great reception on both AM and FM. The HD works well as well.
