I had my z2 installed a couple days ago. Everything worked great except the bypass was not done. I took it back to the installer to have the 2 wire bypass done with the directions from http://www.sminntech.com/z1flash.html#newbypass. The bypass worked but shut off at 20mph + above. The installer claimed that he took out the speed sensor also.
I also did the update listed here:
CDROM ISO!!!!
1. Download this 30MB file: http://www.megaupload.com/?d=4T5MBJL7
2. Burn to CD or DVD as an image, not using built-in windows burning.
3. Insert in Z2, press Map, and run the update! (e-brake must be applied or wire grounded
4. Press the recessed reset button once, and your Z2 is now 2-wire bypassable
Problems now occuring:
1. The navigation is around 100ft off. It is slower and sometimes faces the wrong direction.
2. The bypass still isnt working. Should the speed sensor be hooked back up and I'll just tamper with the wiring itself on the wire #2 on the bypass?
Any help would be great please!!
