recalibrate avic d3 navigation
By gmalfavon1 · Jul 02, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,273 views
Posted Jul 02, 2008 · 03:25 UTC#1
i bought my d3 just a few days ago bought it off my friend didn't come with the nav disc so i ordered one seems to work fine.
my problem is that i inserted my nav disc and the navi says im in the middle of nowhere in L.A i need to recalibrate it to AZ how do i do so.
thanks Mike
Posted Jul 02, 2008 · 03:39 UTC#2
If the nav is showing you in LA, either the disk is no good or you aren't getting a good GPS signal. Is the disk you bough the actual Pioneer nav disk or is it a burned copy?
1. Check to make sure you are getting a good satellite signal to the unit.
2. Reset the unit to factory settings and clear all the calibration/learning data thatis in tere from the previous car. LINK
3. Try a different disk.
Posted Jul 02, 2008 · 21:34 UTC#3
i bought the disk on ebay said it was the original. it was sealed
i dont accually have the avic in my car i just connected my power cable to my batery and ground as well just to test it
i was reading other forums and it said to just reset it and pop in disc and it should find your position
Posted Jul 02, 2008 · 22:08 UTC#4
Ummm... you have the antenna plugged in, right???
And it's got a clear view of the sky... and you are not in a garage or anything like that?
Anyway, if you clear out the old learning info like in the link I put in up there, and the unit has a good satellite signal, it may take a little driving around before it will calibrate/adjust/find it's current position.
Posted Jul 03, 2008 · 03:02 UTC#5
yea my antennas' plugged in.the avic it was underneath my hood it was popped to get the cables on batt thanks ,dude uve been alot of help once i get it installed ill reset it and i think all should go well
the only problems gonna be customize my dash for it to fit i have a 97 dodge avenger its only a bin and a half
