Problems with CDDB Upgrade
By BMWJ17 · Aug 21, 2006in Problems/Troubleshooting💬 7 posts👁️ 1,682 views
Posted Aug 21, 2006 · 04:38 UTC#1
Ok I burned the CDDB using NERO on a CD-RW now I put the disk in and I let it update I left the car in garage and waited about 10:00 Min and went back to garage to check on progress and it said Error Upgrade Failed. So before putting my fist through My Z-1 I ejected the CD-RW from it and went inside and Found a Brand new CD-RW and burned it again new disk and all I put it in the Z-1 and it went through the normal bull crap and asked if I would like to upgrade so I acknowledged and it Started and Picked up where the Last CD-RW left Off at %53 Completion and Immediately put up the error Screen again. So I came back inside and "Re-Downloaded" the CDDB from Pioneer and Burned it to yet another CD-RW only to have it again Register at %53 an fail again. So I went ahead and "hit The Reset Button" on the Z-1 and it agin gave the same results. Upon these results I then push the Reset Factory Default Settings and Received the same results. Any suggestions? ???? Any help would be greatly appreciated.
Posted Aug 21, 2006 · 05:01 UTC#2
make sure ur not usin windows 2 burn it on a disc. don't put the files in ne folders, put them in the root directory. i used nero 7 n it worked great.
Posted Aug 21, 2006 · 10:57 UTC#3
Well BMWJ17 did say he was using nero. I used that myself. I noticed the he was using CD-RW's. I used regular CD-R's.
If it keeps stopping at 53% you might have bad files, or it might be a problem with the CD-RW, try a regular CD and burn it slow.
Make sure you do the cd format as listed on the pioneer web site.
Posted Aug 21, 2006 · 14:48 UTC#4
I think DB has something with the CD-R vs CD-RW. Also, are you finalizing the CD after you burn it?
Posted Aug 21, 2006 · 19:07 UTC#5
Yeah I have allowed the Disk to finalize. I think my next step will be to try a CD-R in lieu of the RW that I am currently using. Thank you all for the input.
Posted Aug 29, 2006 · 03:35 UTC#6
Well I reloaded the CDDB to a CD-R and it worked. I am not sure what the difference was but it worked. Thanks all for you assistance.
Posted Aug 29, 2006 · 12:38 UTC#7
Well, CD-RW disks are "harder" to read than just normal CD-R's. Something about the material that is burned into reflects the laser light less than CD-R making it harder for some cd drives to read them.
http://www.osta.org/technology/cdqa6.htm
(second paragraph)
I think that might have something to do with it. Although I would have figured that most cd drives these days are made to read almost anything.
