F90BT zooming into outer space...
By vastmax · Jul 03, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,571 views
Posted Jul 03, 2008 · 13:19 UTC#1
I've noticed a couple times my screen goes from my current location., starts zooming out, and never stops until i see the whole earth, then my screen is all black. I can hit the current location info button and it stills shows what it should. The first time it happened it was in outer space for 2-3 minutes, then it zoomed right back into where it should be.
I've tried playing with smart zoom and it still does it. It usually goes back to normal when i start it up again.
Anyone else had this happen?
Posted Jul 03, 2008 · 16:10 UTC#2
I've had that happen a few times. It's usually when I have tried to zoom out. Did this happen to you after you tried to manually zoom out a couple of notches? What I 'think' was happening in my case is that I was being impatient and/or holding the multi-switch down a bit too long and it just locked up in the zoom-out mode. Also happened once when I was trying to mute but had some down pressure on the knob. It's annoying but usually (like you said) corrects itself in a couple of seconds or two.
Posted Jul 05, 2008 · 07:00 UTC#3
I does it while i'm just driving, i'm not touching any buttons.
Posted Jul 07, 2008 · 22:32 UTC#4
[snip]
Yes, it has happened a few times on my F700BT when switching from 3D to 2D. Switching back to 3D and then 2D again fixed it.
Posted Feb 26, 2009 · 19:59 UTC#5
:D Did you guys see any UFO's?
