Using Navigation while listining to music
By gti689 · Jul 04, 2008in General💬 6 posts👁️ 1,066 views
Posted Jul 04, 2008 · 04:08 UTC#1
I just purchased a pioneer D3. It was a demo version at a shop, but had never been installed. I was wondering when i use my navigation and listing to music at the same time, The voice that tells me when to turn doesn't go off, i only hear a beep. But when i press the button it tells me. Is this something i can fix in the settings?
Posted Jul 04, 2008 · 04:40 UTC#2
You can turn voice guidance on and off and adjust it's volume in the VOLUME category in the nav settings menu
Posted Jul 04, 2008 · 04:52 UTC#3
The volume is turned up. But will not go off unless i press the button
Posted Jul 04, 2008 · 05:24 UTC#4
Also i wont allow me to look at all the views only the first 2? Only options it allows me to access is Map view and drivers view?
Posted Jul 04, 2008 · 05:34 UTC#5
Eject the nav disk and reset the unit to factory settings. Maybe it is in demo mode...
Turn the unit on.
Go to NAV SETTINGS > HARDWARE INFO > 3D CALIBRATION and delete the distance, speed pulse, and learning status values. Just press each one and hit clear.
Then with the power still on, push the reset button (the pinhole button on the top left of the face of the unit) for a few seconds.
That should reset the unit to run as if it just came out of the box.
Posted Jul 04, 2008 · 23:30 UTC#6
Thanks! worked perfect
