does anyone know where i can order an install kit for the avic D3 to fit in a 1999 Saab 93? in the kit i need the mounting aparatus and also the frame around it?? thanks
Posted Jul 04, 2008 · 14:49 UTC#1
Crutchfield, Circuit City, Best buy, any local car stereo shop...
Although under investigation, Metra doesn't list any install kits for your car, and even says that the stock radio is a double-DIN unit. If that's so, chances are you won't need a mounting kit. It should bolt right in using the stock mounting hardware and not need a new trim bezel.
Can you post a pic of your current radio/dashboard?
