I am about to install everything for my D3 and hooked have begun hooking up my Crutchfield purchased Wiring Harness for my Infiniti QX4. I have a few wiring questions. Below is a lost of the wires that I connected, and some that was not sure about and/or did not use.
I am being verbose as I can so my question gets answered! Thanks in advance! What is in BOLD, I did not hook up, what is in BLUE are questions I have of you all.
Yellow - constant +12v - CONNECTED
Red - accy +12v - CONNECTED
Black - Ground - Will connect when doing installation.
Orange/white - Illumination - CONNECTED (Had solid Orange)
Lt. Green - Parking Brake (Will be used via bypass?)
PINK (Car Speed Signal Input) - I have no idea what I am looking for to tap into?
Purple/white - Reverse Input - NOT CONNECTED
Blue - Power Antenna - CONNECTED
Blue/white (in the rca harness) - Not using an AMP, I do not think I have a factory AMP?
Yellow/Black (in the rca harness) - Cell mute (though most use it for bypass) - NOT CONNECTED
White - Left Front Speaker + - CONNECTED
White/Black - Left Front Speaker - CONNECTED
Gray - Right Front Speaker - CONNECTED
Gray/Black - Right Front Speaker - CONNECTED
Green - Left Rear Speaker - CONNECTED
Green/Black - Left Rear Speaker - CONNECTED
Purple - Right Rear - NOT USED DON'T THINK I NEED IT CONNECTED
Purple/Black - Right Rear - NOT USED DON'T THINK I NEED IT CONNECTED
Light Green - NOT CONNECTED
My Crutchfield harness (small one in photo below) still has a black/white wire and a blue/white wire available. There are the green and green/black wires I am not using because I assume they are for speakers 6 and 7 if I had them. However I do have factory door pillar tweeters, I assume they are hooked up in parallel but I will likely connect the loose green wires as well.
SO far so good but I am not too sure how I am suppose to hook up the Pink wire, what am I tapping into in the car again? How about the other items I noted in BOLD, should I use any of them?
Full size photo here: http://i60.photobucket.com/albums/h11/64suicides/Avic/IMG_1747.jpg
I also moved the Black/Yellow wire in preparation for the Bypass, I can hook the Parking Brake and do if I need to hook up the Mute wire to this.
Original Location: http://i60.photobucket.com/albums/h11/64suicides/Avic/IMG_1750.jpg
New Location: http://i60.photobucket.com/albums/h11/64suicides/Avic/IMG_1751.jpg
