Anyone know what Pioneer or through personal experience what the best brand od SD card is for the F900? I would like a 32gig if possible.
Thanks,
Jan
Thanks,
Jan
All SD cards will work the same with the F series units. The difference between the brands/prices are how long that card is going to last you. Cheap cards have a tendency to go bad after a while. The best brands I've found to be Sandisk, PNY, or Kingston...
A 32 gig SD card (if you can find one) will cost you A LOT of money. Same goes for a high capacity USB stick.
You can get a GOOD 16GB SD card for around $75 or more. The cheaper ones aren't all that desirable, much like cheap USB cards or cheap CD/DVD media. They don't tend to last.
I don't know if it's something you want to hear or not, but IMO your best bang for the buck would be to get an ipod.
Or maybe something like a small portable USB drive would be better?
If you plan to use your PC's SD card reader make sure it is compatible with the new SDHC(usually 4gb and up) cards. Or else you will have to shell out some more $ for a new reader.
