No Audio at all!!
By kurtcav337 · Jul 08, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,689 views
Posted Jul 08, 2008 · 22:46 UTC#1
installed the unit a couple weeks ago. bypassed the entire stock system because i put in aftermarket speakers. i am using the internal amp and have the speakers connected directly to the F700BT.
it worked great for the first 2 weeks. i went on a road trip and all audio cut out for like 10-15 min. i thought it was a fluke. it did it the other day again and resetting the system didn't even work. then it mysteriously came back on after i started the car a few times.
it just did it again yesterday and today (it's still not working) and i pulled the unit out to double check the connections and everything looks fine.
ideas?
(i can't even hear the annoying beep from using the touch screen)
Posted Jul 08, 2008 · 23:07 UTC#2
really check the wire harnesses. They take a good ammounbt of force to put in, and may look installed, but not. 10 to 1 thats it
Posted Jul 09, 2008 · 00:12 UTC#3
Double check the mute connection in the harness, any chance that it's being grounded?
Posted Jul 09, 2008 · 01:19 UTC#4
The internal amp shuts down if there is a short on just one of the speakers or wire. Try disconnecting them all, and just hook up one at a time to determine which speakers is shutting it down.
Posted Jul 09, 2008 · 15:55 UTC#5
I did this. I kept the radio removed from the dash while i tested it and the clip was fully in and snug.
It is grounded but I used the bypass.
This seems like it must be the issue. I am going to remove the doors this weekend and make sure there are no shorts.
For the time being though.. it decided to work today.
Posted Jul 13, 2008 · 17:01 UTC#6
Try a different source...
Mine cuts out when playing iPod, but sounds 100% fine when I use a CD...
I really hate this thing.
