How to Fix Black Screen problem
By FinJHL · Jul 09, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,645 views
Posted Jul 09, 2008 · 08:21 UTC#1
I have Avic-D1 and I had problems with screen (everything works but screen was only black). Maybe there was some text but i couldn`t see what it was.
- You need Service manual for fixing this (http://www.eserviceinfo.com/downloadsm/ ... IC-D1.html)
- You need also some solder skills
- also you need to know how to measure resistanse
Open AVIC
-> Remove System unit (see manual)
-> On the system unit is black light fuses (below) (see manual)
measure Fuse FU1821, if resistanse is near 0 -> OK (bigger problem)
If Resistanse is infinity -> change fuse or sold it fogether
There is also few other fuse on System unit (both sides), you can also measure those components easily ( Fuses are FU xxxx ), if 1820 wasn`t broken.
If you have black screen problem, this may helps you. This helps me.
thnx.
Posted Jul 09, 2008 · 14:34 UTC#2
Glad I havent had this issue but i dont think its common place in a d3
Posted Jul 10, 2008 · 04:28 UTC#3
I just recently bought a car and am having this same problem.
The buttons etc work and the screen can kind of be seen when the sun is directed on it a certain way but just very lightly.
The touch screen still works etc. I tried holding the reset button which just
reseted all the settings it seems however screen still cant see anything.
Was that the same problem you were having?
Posted Jul 10, 2008 · 09:51 UTC#4
It could be same problem (screen Fuse problem).
In my case touch screen works fine but no matter what you do it`s all the time black (no colors and lighs).
Posted Jul 24, 2008 · 11:01 UTC#5
That is exactly what mine is doing! Thank you so much I am going to try this right away. I was getting very discouraged that I might have to send this in for repair when I knew it could be something I could fix myself.
