Intervals on the playback from the music library on the Z2? Obviously, live albums are the biggest issue with this. Is there a setting so it doesn't "jump" from track-to-track?
Wow 73 views and nothing??? Thanks guys.
Maybe nobody knows the answer, I sure don't!
I don't either, but I'd like to know as well. ![]()
Well thats a good question I dont know either ![]()
Good to see that others are curious too.
I understand that iPods do not do this but have yet to download onto one.
I can't wait to toss all my CDs. Of course, I will have to hold on to the live ones until this mystery is solved.
I've sent a message to Pioneer regarding this, will post back upon their reply.
Ugh. So I emailed Pioneer about this issue, here's the reply I received back from them:
We suggest you give us a call at 1-800-421-1404 and we will try and assist you with this matter.
Thank You,
Clark
Customer Service Representative
So I rang them up, and I was told that it's "built in" and cannot be changed. The rep I spoke to tried to tell me that the TOC (Table of Contents) has the 2 second interval coded in. When I explained that if you play the disc there is no pause, only if the disc is recorded onto the harddrive, that's when he told me it was a "built in" feature. So I explained to him that it's really annoying, and asked if Pioneer was thinking of fixing it in any upcoming releases of the AVIC-Zx line. He kind of laughed and said that it's "not really a priority for us, so no."
I'm kind of jaded right now. ![]()
Why not just record the live album as a single track? I use Toast to do just that. I manually remove the 2-second gap that you are referring to and then the concert plays non-stop. You take your AIFF file CD and convert it to a 1-track MP3, then convert that back to an AIFF file that has no track breaks. In a car setting, the lossiness issue from converting back and forth is probably not going to be noticeable.
Well, as long as it's not a priority for them then we should all be satisfied. I swear customer service has died a while ago in this country. Was this guy a supervisor? I'm willing to bet he said his name is "Tom" but he's clearly speaking to you from India or somewhere. lol
Thanks for trying though, man. I appreciate the update!
Thanks for the input. I would like to add the live albums to the library and I don't believe there is a way to do that through Toast or another program of the like. It's also very annoying on albums like Dark Side of the Moon and The Wall . Dark Side is meant to be listened to in its entirety and without interruption.
I think the only way to listen to these albums without the "breaks" is by the old-fashioned inserting of the disc each time. You also can not download music from an MP3 disc to the Library.
Paulpop72,
You are not getting it.
You are or WOULD be adding the live album to your AVIC library. Again, you are playing the retail CD as an AIFF file that you are going to use Toast to convert into a single track MP3 without any breaks. Once you have that concert as one long continuous MP3 file, you will then convert that MP3 file into what amounts to a commercial AIFF file that the AVIC will treat just like your original retail Dark Side of the Moon CD. You insert that disc and it starts recording it to your library. You then will search for the album Dark Side of the Moon and when it is found, you will see Album Name: Dark Side of the Moon, Album Artist: Pink Floyd. As a place holder for Track or Song Name, you can just say something like Live Concert. My point is that it will do what you want. I do that all the time.
I imagine by making it one track there will be no way to skip ahead to certain songs other than just fast-forwarding, correct? Thanks for the info about Toast.
That is correct. There is supposed to be a way to do that, but I have not been able to make it work. If I put in the ability to go directly ahead 5 or 6 minutes (to the next track), then I will get that pause (even if just for half of a second.
