Back of the D3
By tysmith14 · Jul 11, 2008in General💬 6 posts👁️ 907 views
Posted Jul 11, 2008 · 21:46 UTC#1
Does anyone know where I can see a picture of the D3 on the net so I know what I am looking at before I actually take it out to work on it?
Thanks in advance!
Posted Jul 12, 2008 · 01:09 UTC#3
I looked on that link under documents and cant find it. Am I doing something wrong?
Posted Jul 12, 2008 · 04:13 UTC#5
Thanks for the pic, I am about to add an amp and sub, (previous thread) I cant see where those plug into the back of the unit, such as RCA cables and someone had mentioned there is a sub jack on the back? How is that used?
Posted Jul 12, 2008 · 06:44 UTC#6
Look at picture number 3 at that link. There is a white wiring harness on the right side of the picture with a bunch of RCA connectors on it. That's where all the pre-amp outputs and AV inputs are located.
You plug you RCA cables into that harness, and that harness plugs into the back of the D3 at the white AV IN/OUT at the bottom right, directly next to the power/speaker harness.
