Lexus GS300 Help!
By jcat_GS3 · Jul 14, 2008in General💬 7 posts👁️ 3,817 views
Posted Jul 14, 2008 · 03:57 UTC#1
hey all, I'm brand new as you can see. I'm considering buying a D3 and I want to know if anyone has installed this in a 2nd Gen (98-05) GS without factory nav. Any experiences, pics, whatever are helpful. Specifically I want to know if the factory changer and factory subwoofer can be utilized in any way, and how it looks installed/how easy it is to install or how expensive it is to have it installed.
Posted Jul 14, 2008 · 04:13 UTC#2
It wont be hard, you'll need:
-Toyota 87 & up wiring harness
-Toyota double din dash kit
-possibly a Speakerwire - RCA converter
I am not sure how the sub is wired in a GS300 so you may or may not need these.
Posted Jul 14, 2008 · 04:21 UTC#3
is that really it? every other thing i've looked at says i'll lose the factory amp/sub and changer control.
Posted Jul 14, 2008 · 04:50 UTC#4
The sub can be fixed easily, the changer not so much. Its just how creative you want to get.
Posted Jul 14, 2008 · 05:08 UTC#5
any input on how the factory amp/sub can still be used? I think i know of a way to mod the changer so that it will work utilizing the IP bus, even though i'll have IPod capability id rather not lose the changer, still nice to have. I dont want to have to add or change out any components other than the head unit itself.
Posted Jul 14, 2008 · 06:50 UTC#6
I installed d3 in my 2005 rx330. Works and looks great like factory.
gs will be a cake walk. factory lcd will go out pretty soon, so might as well do it now. good luck.
Posted Jul 14, 2008 · 19:54 UTC#7
I did an install on my 2001 GS430 with Factory Pioneer System (Nakamichi and Mark Levinson systems might be different)
Good reading WITH pics http://www.clublexus.com/forums/showthread.php?t=286180
You use TWO harnesses for a factory plug install.
Metra 70-8113 2000-up Toyota / Lexus Amp Sys this plugs the D3 into the Toyo factory batt, ACC, ground and dimmer
Metra 70-1761 1987+ up Toyota Harness you'll only use the speaker patch half near the factory (CRAP) amp.
Here are some wire colors for the '01GS430
Blue/Yellow stripe (battery (always HOT))
Gray ACC (switched)
White/ Black Stripe (Ground)
Light Green (Illumination)
FACTORY PIONEER CHANGER
• You can order an internal PCB board and convert it for use with the D3. I think it costs $75 if you're willing to do the install yourself.
FACTORY SUB
• It is 5ohm so you are SOL on re-using it. The factory AMP has some sort of proprietary Bus signal to turn it on/off that only works with OEM Lexus head units so you can forget using that too.
The Metra double din kit looks lik A$$ since it is textured black. You can order a JDM double din plate from Carson Lexus it is a PERFECT match to the rest of the dash.
Right now I am running my D3 straight to the stock speakers and it honestly sounds better than the factory system with the amp and 10"sub. I just got my door speaker adapters and will be hooking my 6 channel amp/sub and 6.5" speakers up this weekend.
