how do i bypass in order to play the dvd player? i would like instructions on how to do this. can somebody send me the instructions on how to do this on the avic d3? also i am having the same problems on the ppc 6800 to connect on the avic d3. i can recognize it on my phone but when i try to connect it says connection error. when u do the paring on the d3 does it just keep saying paring until it pairs on the d3 or do u back up once it's paired up on the phone? somebody please help soon!!!!! ![]()
how do i by pass on the avic d3 and how can i connectmy phon
I don't know about the phone... but there are 4 topics stickied at the top of the D-series hacks/mods board that have more than enough info and detail to get you going on the bypass.
The stupid HTC pc6800 has WM6 and it doesn't sync correctly to the btb200. I'm sure you recieved the "invalid devide" error message, correct?
You have to download jetware mobile software http://www.jetwaremobile.com and download the 30day trial software. Try it and it should fix your problem. The only downside is that after 30 days, you will be locked out of the program so you're going to have to buy it.
Instructions:
Step 1:
Go to your phone, tap on "internet explorer" and type in jetwaremobile.com
Step 2:
Download the 1.31 version which has a "click here to install" link.
Step 3:
Install the cab and install it to the device(DO NOT INSTALL TO THE SD CARD!)
Step 4:
After it's been installed, do a hard reset by getting the stylus out of your phone and with the pointy ending of the stylus, push the small button that is to the left of the power plug socket(under the SD card slot).
Step 5:
Once your phone has been restarted, get the stylus and tap on
Start -> Programs -> File programs.
Step 6:
When you're on the file programs window, on the top right corner, there will be an arrow pointing down and next to it, it will say "Storage Card". With the stylus, tap onto the arrow and select device. Tap onto the program files folder and finally, tap on the jetware folder. Then, there will be only one file there. Tap on it once and viola.
After you've successfully done steps 1 through 6, go to your car and once the navi unit is fully working, the phone will give you a notification that CD-BTB200 wants to connect to your phone. It will prompt you for a password. Type in 0000(four zeros) and select connect. Register your phone and it should be fully working.
Let me know if you run into other problems
