Really Bad Alternator Whine
By dye4metal · Jul 17, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,024 views
Posted Jul 17, 2008 · 02:20 UTC#1
i mean its one thing after another with my D3. i have a REALLY bad whine off the 4 channel RCAs i have. im not sure if its the unit or my grounding point on my amp. ive never heard it this bad before and i had a POS jensen flipout before
Posted Jul 17, 2008 · 04:45 UTC#2
Plug something with RCA outputs (like an ipod, zune, or portable CD/DVD player) into the RCA cables (On the D3 side of them) and see if the whine is still there. If it isn't, the D3 is causing the noise. If it is, either the RCA cables or amp/amp wiring is the cause.
Posted Jul 17, 2008 · 20:48 UTC#4
ill try grounding the RCAs. i dont have anything at the moment to hook an ipod to it.
Posted Jul 18, 2008 · 20:13 UTC#5
Check your battery cables. The factory radio in our Jeep developed a bad alternator whine, which ended up being the ground terminal on the battery was corroded and loose. I figured it out when the odometer started flickering and the whine turned into a crackle.
Posted Jul 22, 2008 · 01:30 UTC#6
RCA Grounding worked like a charm. i have the big 3 done in 0 guage and i have 2 runs of 0 guage for power to the back of my tahoe and a yellow top. i dont think power and grounding is the issue lol :P
