no nav/bluetooth sound
By zeller · Jul 18, 2008in Problems/Troubleshooting💬 6 posts👁️ 911 views
Posted Jul 18, 2008 · 16:19 UTC#1
I apologize that I just posted this under the the N-series by mistake. So here it is under the the proper heading.
This is my first post so please be kind. I just had a Z3 installed in a 2006 Chrysler 300c. I receive no sound from the navigation woman or bluetooth. Other people can hear me if I make a call, but I have no sound coming from the speakers. Also, if music is playing it will mute for or a call or nav instructions. I'm going back to my installer next week & I'm hoping I can get some info to help him out. Thank you in advance. Great site!
Posted Jul 19, 2008 · 18:21 UTC#2
Double check your settings as listed below from the manual:
Changing the voice output of the navigation guidance. You can set the speaker to output the navigation guidance and phone voice, etc.
1 Touch [Guide/Tel SP] in the System Settings menu.
Each touch of [Guide/Tel SP] changes the settings as follows:
• Left SP — Uses only the front left speaker
• Right SP — Uses only the front right speaker
• L+R SP — Uses both the front right and left speakers
Hopefully yours is set in Right SP...
Posted Jul 20, 2008 · 05:10 UTC#3
Mine is set to both left & right. This is why I'm receiving no sound at all for these two functions. You're saying if I set it right only I'll start to hear sound. Why would this matter? Thank you for your help.
Posted Jul 20, 2008 · 05:37 UTC#4
I've just tried driving around with all three options selected (L+R, L only, & R only). My music does mute so I know the nav is taking, but there is still no sound. I've read somewhere it might be an amp issue & that I'll have to hook the front channel to the rear in the wire harness. I'm not sure if this was done by my installer or not. I guess I'll mention it to him & see what he says. If that is what is happening would I still get sound from my other sources through all speakers like I currently am? Thanks for the help!
Posted Jul 20, 2008 · 12:36 UTC#5
If you have a factory amp installed, chances are the installer didn't interface it with the AVIC correctly...
Posted Jul 20, 2008 · 17:39 UTC#6
take it out and make sure he connected the avics system remote control wire to the ams remote wire. its the blue and white wire on the rca connector. when i hooked the z in myne a while back (my first car with an upgraded system) i forgot to connect that wire, and for an entire day i was puzzled for y i wasnt getting sound.
