f700 video extensions that play
By freshpl · Jul 18, 2008in General💬 17 posts👁️ 3,436 views
Posted Jul 18, 2008 · 22:32 UTC#1
what video extensions will play in f700
Posted Jul 19, 2008 · 18:32 UTC#3
I still haven't found a free converter which makes the video full size to the screen and not choppy as all hell. Has anyone?
Posted Jul 19, 2008 · 18:52 UTC#4
what format are you looking to convert to?
Posted Jul 19, 2008 · 23:02 UTC#5
Ok i am in the same boat.
I converted to mp4 and put it on the SD card or the USB flash and my navi can't find it....
Any ideas why it won't?
Thanks.
Posted Jul 19, 2008 · 23:59 UTC#6
sry for the probably stupid but i have no idea...is mp4 and mpeg4 the same format or very similar or not at all.....cuz i use videora mpeg4 converter and it works just fine. jus throwin it out there
Posted Jul 20, 2008 · 00:35 UTC#7
so you are able to load it up on the sd card and play w/o any issues?
via videora?
im going to try that now anyways though...
Posted Jul 20, 2008 · 00:38 UTC#8
via videora?
ummmmm good question lol i mainly use it for ipods i was jus throwin it out there cuz it makes a clean conversion. but i dont see y not, cant u load anything onto an sd card?
Posted Jul 20, 2008 · 00:50 UTC#9
mp3 work fine on the SD.
just the mp4 video files.....
Posted Jul 21, 2008 · 02:53 UTC#10
Ok.
So I was able to get video to play off of the SD card.
Now my question is...how can i get it so that it will play full screen instead of half that it is doing right now.
thanks!
Posted Jul 21, 2008 · 03:57 UTC#11
its playing half like widescreen or half between the left and right side?
Posted Jul 21, 2008 · 04:05 UTC#12
Ok.
thanks!
With the video paused go into the av setup menu. The option is in there.
If it is already set to "full" its the video format your playing and not the unit.
Posted Jul 21, 2008 · 16:53 UTC#13
YES exactly!!! kinda both.
slimmer wide screen with the sides cut off too.
can that be fixed?
and i will try the AV format full screen thing.
thanks.
Posted Jul 21, 2008 · 17:13 UTC#14
The screen's resolution is 800x480... if your videos are encoded at a lower resolution there is a chance of that happening.
Posted Jul 23, 2008 · 02:39 UTC#15
What video format's play on SD? I added some MPEGs, loaded my SD card, switched to Video, and it says "Impossible to play all videos". Why? I dropped the vids in a Video folder I created parallel to a music folder I have with my MP3s.
Thoughts or success with this appreciated. I have a 900BT.
Time
Posted Jul 23, 2008 · 13:19 UTC#16
Time
Go here: http://www.avic411.com/forum/viewtopic.php?t=15876
Download the manual, and go to page 188.
Basically, you need them to be in MP4 format, not MPG/MPEG. Also, some WMV files will play as well.
Posted Jul 23, 2008 · 13:29 UTC#17
Thanks Hifi. You need to be made a mod around here!
Time
