Firmware Version Posting
By gjas18 · Jul 18, 2008in General💬 4 posts👁️ 1,955 views
Posted Jul 18, 2008 · 23:41 UTC#1
I wanted to start a thread where people can post what the firmware version is on their particular unit along with the date of manufacture (sticker on the box). It seems to me there are some issues some people are having where others are perfectly fine like the bluetooth call quality issue. It sounds to me like some units might have a slightly newer or older version of software than others.
I would like to see if there is a pattern and it might reveal if some these issues people have been having may have already been fixed by a slightly newer firmware in another persons unit.
The firmware and map version is listed under System Settings -> Service Information. The DOM (date of manufacture) is on a sticker on the side of the box. BS (Bluetooth Software) version is under Phone -> Phone Settings -> Bluetooth Software Update.
Anyway post in this format.
Model: F700/F900/F90
Firmware: 1.xxxxxx
Map: 01.xxxxxx
BS: HWxxx-SWxxx
DOM: xx May 2008
VERY BRIEF LIST of issues encountered or if your unit works fine BOOT TIME IS NOT ONE OF THESE ISSUES PIONEER HAS ALREADY STATED THAT WILL NOT CHANGE SIGNIFICANTLY
Posted Jul 18, 2008 · 23:46 UTC#2
Model: F700
Firmware: 1.000900
Map: 01.000200
BS: HW100-SW290
DOM: 26 May 2008
*Map changes from 3D to 2D randomly
*Freezes during Nav occasionally
*Comma instead of point
*Boxes present on map when no route planned
*Map will stop following the arrow until map button is pressed occasional during Nav
*Bluetooth call quality good if "Echo Cancel" is turned off
*Buttons presses very responsive roughly 30 seconds after startup dialog disappears
*XM station listing VERY slow and can't press buttons until station art loads
*No clock problems it is always spot on
Posted Jul 19, 2008 · 03:02 UTC#3
Model: F700
Firmware: 1.000600
Map: 01.000200
BS: HW100-SW290
DOM: May 2008
* Boxes present on map when no route planned
* Freezes during Nav occasionally
* Map will stop following the arrow until map button is pressed occasional during Nav
* Bluetooth call quality good
* Bluetooth reconnect time is sometimes good and sometimes takes ~10 min to connect.
* Clocks have never been on correct time
* System will reset itself
* IPOD connection will drop, have to unplug/plug
* Voice recognition does not work very well
Posted Jul 20, 2008 · 23:38 UTC#4
same as gjas18
Model: F700
Firmware: 1.000900
Map: 01.000200
BS: HW100-SW290
DOM: May 2008
