I was looking through the user manual for my F90BT and I can see where HD radio multicast is displayed but I have no idea how to access it. Am I just missing something obvious here ?
thanks
thanks
You need the HD radio tuner to receive HD radio broadcasts.
never mind I am retarded I have the HD tuner I was just having problems tuning in the multicast stuff I adjusted some options for seeking and all is well.
ad lib, what settings did you end up using? When I first installed my unit multicast worked fine, was able to save presets, etc. Now the Multicast info doesn't show up and, aside from the saved presets, I can't select subprograms from the HD stations.
My settings:
- Antenna set to powered at all times (not just radio)
- Local set to off (also tried w/ Local on and level set to 1)
- Analog/digital blending on and seek set to HD
