Mustang GT 2007 Ground Problem
By woodypro · Aug 24, 2006in Problems/Troubleshooting💬 17 posts👁️ 4,186 views
Posted Aug 24, 2006 · 22:40 UTC#1
I just install AVIC-Z1 in my Mustang 2007 and my amp does not work they only way i can make them work is by apply a ground on my RCA ground side but all my ground on my radio are double check and OK can some one help me i use they original ampl that come whit the car.
Thank's
Posted Aug 27, 2006 · 06:22 UTC#2
Thank's
You are going to have to explain your problem a bit more. What was your original stereo system? Where did you install the ground at? And please don't smoke any dope before you post this time....
Posted Aug 27, 2006 · 14:30 UTC#3
My guess is you need to ground the factory amp back through the Z1. Your harness adapter should have provisions for that.
Posted Aug 27, 2006 · 23:03 UTC#4
Shaker 1000 is my original radio and my groud is comming from a ground wire that was they original ground for the shaker
Posted Aug 27, 2006 · 23:50 UTC#5
When you got your wiring kit... you should have got a 4 pin plug (separate from the main harness) YES..?
OK, the 2 gray wires need to be wired together (with a 4k7 give or take resistor between them)
THEN your amp will turn on properly... IF you just connect the wires together, you amp will THUMP on turn on (not good)
Posted Aug 28, 2006 · 03:10 UTC#6
Ok thank's i will check tomorow but did i tell you that i install and glaudio amp in i check this thank's again
Posted Aug 28, 2006 · 11:27 UTC#7
You said you had the factory Shaker 1000 installed...
Please clarify what system you have in place, factory, or aftermarket. without that, any help we're tying to provide will likely be useless.
If you've gone aftermarket for the amp, is there any way you can go back to factory specs?
Posted Aug 28, 2006 · 22:52 UTC#8
I can go back to factory amp but now they only thing i use from the factory is the sub woofer i install JL audio and a kicker if i try another radio everything work OK seem like it is the radio that dont give ground to my RCA plug because i just touch them whit ground wire and it work sorry about my english and thank's for your help
Posted Aug 28, 2006 · 22:55 UTC#9
So, when you use the factory amp, everyting works fine YES?
Posted Aug 29, 2006 · 03:23 UTC#10
Nothing work original or not seem like no ground comming out for rca from radio
Posted Aug 29, 2006 · 11:50 UTC#11
How many wiring harness connectors did you get with the wiring kit for the Mustang?
One, or two...
Posted Aug 29, 2006 · 20:23 UTC#12
2 one radio and 1 camera harness
Posted Aug 29, 2006 · 20:35 UTC#13
IGNORING THE CAMERA HARNESS...
Did the harness you got for your Stang look like thjis one...
http://www.crutchfield.com/S-FiNrKomPbB ... =120705521
(2 separate pieces)
Posted Aug 30, 2006 · 18:22 UTC#14
man jjust bypass the factory amp and run everything off the deck and after market speakers now your factory amps one controls the tweeters and the other controls the woofer so make sure u get a proper diagram if u attempt to do this
Posted Aug 30, 2006 · 22:40 UTC#15
where can i buy that parts in canada
thankx
Posted Aug 31, 2006 · 00:15 UTC#16
cruthfield should be able to ship to Canada... try them, you never know
OTHERWISE
Try your local audio superstore... It's a Metra Wiring Kit (don't know the metra number though)
Posted Aug 31, 2006 · 00:27 UTC#17
cruthfield not ship in canada juste usa
