my bypass is not working on AVIC-D3
By sweetguy4now · Jul 27, 2008in General💬 6 posts👁️ 1,262 views
Posted Jul 27, 2008 · 06:50 UTC#1
I have read several posts about bypassing my unit and the picture still turns off after reaching 15 mph ..
I grounded my parking brake wire
I grounded my mute wire
I relocated my mute wire right below the original slot in the wiring harness
Does anyone have an idea ?
Posted Jul 27, 2008 · 13:25 UTC#2
double check that the relocation of the mute wire is correct. from the factory it will be right next to a pink wire. after the relocation it will have an empty slot next to it. also if you use the blue 3M scotchlock splices, they sometimes lose connection on smaller wire. i was having trouble getting my steering wheel interface to work and this turned out to be the culprate. they are really meant for a larger (16 gauge or bigger wire) and unfortunately all of the wiring for this install is pretty tiny stuff. just some stuff to try.
Posted Jul 30, 2008 · 02:54 UTC#3
double check that the pin is in the right location and locked. double check the grounds too.
Posted Jul 30, 2008 · 17:52 UTC#4
I double checked everything , the pin is exactly below the old location . I don't know if I put it in the right way , but I see it through the harness and it is locked in place cause I can't pull it out , so it propably is good . I'll try to ground it somewhere else .
Posted Jul 30, 2008 · 18:13 UTC#5
just tap into the harness ground. much cleaner and you dont have to worry about finding a good ground
Posted Jul 30, 2008 · 19:07 UTC#6
IF the 2 wires' grounds are good and solid, and if the pin/wire has been relocated to the correct position and is inserted properly, it will work, 100% of the time. All you can do is make sure you did those 3 things right. If it doesn't work, one of those 3 points is done incorrectly.
