D-3 Resets randomly
By DAROCK79 · Jul 28, 2008in Problems/Troubleshooting💬 15 posts👁️ 1,480 views
Posted Jul 28, 2008 · 03:35 UTC#1
Hey guys !
I am having a problem with my D3. It happens randomly. It would make 2-3 beeps shut off and reset and comes right back on after a few seconds.
I was wondering if anyone knows why-? Thanks !
Posted Jul 29, 2008 · 00:58 UTC#2
Anybody-? :(
Posted Jul 29, 2008 · 01:17 UTC#3
Same thing happened to me today for the first time.
Why?
Because it is a piece of crap.
Posted Jul 29, 2008 · 01:47 UTC#4
It happened to me prior to selling it. Nav would go black, reset, and set all my settings to default. However music continued to play uninterruptedly which eradicates the idea of a loose connection.
Posted Jul 29, 2008 · 03:47 UTC#5
So is there a fix-?
Posted Jul 29, 2008 · 05:44 UTC#6
Could it be overheating?
Posted Jul 29, 2008 · 08:12 UTC#7
I had this happen to two D3's. It would also put me in NY often. I didn't see this problem with my third D3 before I sold it though.
Posted Jul 29, 2008 · 15:25 UTC#8
So maybe I got a bad unit-? I got it from Crutchfield. I had the unit installed twice. The first time it work fine, but I had to remove it and replace because the GMOS was bad, so I replaced it with a PAC adapter for my 04 Escalade. And ever since then, its been shutting off. I hope somebody knows whats up.
Posted Jul 29, 2008 · 15:42 UTC#9
didn't you also say previously that you got 2 faulty d3's in a row? its probably an internal failure....i would say loose ACC or Constant but i dont think that'd reset your settings..
Posted Jul 29, 2008 · 15:47 UTC#10
same thing happends to my d1...always turns back on but it bull shit...everything still works it happends maybe twice a week and iys not over heating cause the a/c blows on the unit.when its happend
Posted Jul 29, 2008 · 15:52 UTC#11
Could be a solder joint going bad, which is not uncommon. It's almost impossible to fix because some of the pins on these chips are the size of hairs with about the same space between. Plus, you don't know which solder joint is going bad.
It could also be an EEPROM going bad, which could explain the settings getting erased.
Posted Jul 29, 2008 · 16:15 UTC#12
Oh man.
Posted Jul 29, 2008 · 16:18 UTC#13
So, is anybody replacing the units-?
Posted Jul 30, 2008 · 00:50 UTC#14
the setting on mine do not chage on reset like when the car is being cranked over..starting to happen more and more offetn now..
Posted Jul 30, 2008 · 01:39 UTC#15
It resets every now and then, pretty mind boggling
