Night time mode D3??
By itstricked · Jul 30, 2008in Problems/Troubleshooting💬 5 posts👁️ 898 views
Posted Jul 30, 2008 · 20:54 UTC#1
Hi, new here,
Just purchased and had the AVIC-D3 installed in my trailblazer, was wondering if it was possible to switch from day to a night type of mode so it is not so bright, so I would not have to go in and turn the brightness and contrast down. Thanks
Posted Jul 30, 2008 · 21:52 UTC#2
If the illumination wire is hooked up, it should dim when you turn on the headlights.
Try going to the screen settings where you adjust the brightness/dim/etc. Then turn the headlights on and off, you should see the settings switch from day to night. If it doesn't, your dimmer/illumination wire isn't hooked up right.
Posted Jul 31, 2008 · 16:12 UTC#3
Opened it up, so is it orange white to orange white? there is an orange white coming off the unit and a orange and then an orange white
Posted Aug 01, 2008 · 21:35 UTC#4
So I did hook the unit up to the white white, it works and all, but now there is a buzzing in the head unit. and when i step on the gas its there too.
Posted Aug 01, 2008 · 21:52 UTC#5
you hooked up the orange from the unit to the white-white on the harness? thats the problem.
