Listening To Music+Navi
By TurboEight · Jul 31, 2008in General💬 6 posts👁️ 993 views
Posted Jul 31, 2008 · 16:07 UTC#1
Is it possible to have a MP3 CD playing, and use use the navi at the same time.
Since it only has single drive.how will this work?
Let say, I m going on a trip....listening to mp3 cd, then i realize i need to use the navi..(I m lost, need to find my way).
I pop out the cd put in the navi disc., and find my route...
now what?
I can't listen to music during the whole trip?
no, ipod is not an at this point..
I am about to buy a D3 soon..
so I wan to get this straight before i make my purchase.
Posted Jul 31, 2008 · 16:12 UTC#2
you'll need to have a route in memory..ie programe route take disk out and put mp3 disk in..
Posted Jul 31, 2008 · 16:29 UTC#3
1. Put in nav disk
2. Program in route into unit
3. Eject nav disk
4. Play mp3 CD
Every time you need to program in a route, you need to insert the nav disk. But once you set the route, you can remove the nav disk because it will save the current route onto internal flash memory.
Posted Jul 31, 2008 · 17:13 UTC#4
thanks...
I thought you would be the first to post up the answer..
lol
i knew I could count on you though..
thanks..
what if I made a turn NOT following the instructions?
will it re calculate WITHOUT the NAV disc?
or no?
then I would have to hot-swap again?
Posted Jul 31, 2008 · 17:43 UTC#5
It keeps a little bit of the area surrounding the route in memory, so if you don't get TOO far off you might be OK. But yes, you may have to at some point.
You want my 2 cents? Buy an old 5G ipod and put all your music on it. Then you can leave the nav disk in there and never worry about it. I'm telling you, once you have an ipod hooked to that thing, you'll never want to even think about another CD.
Posted Jul 31, 2008 · 19:02 UTC#6
yeap, I was planning on doing that already if this is the situation it was gonna be like..
lets hope the new map update will be a lil better in regard with navi/picking routes.
