New z2 owner here and need a little help
By ndlauer1027 · Jul 31, 2008in General💬 4 posts👁️ 793 views
Posted Jul 31, 2008 · 21:33 UTC#1
Hey everyone, recieved and installed my z2 yesturday. DId the two wire bypass thanks to the info here and it works great. I had just a few questions if anyone could help me out, im sure they are common.
1 is when i have a dvd on and i want to switch to nav screen my rear monitor also switches to the nav screen, is there any way to have my rear monitor stay on the dvd?
2 when i have my ps2 hooked up is there anyway to view it on the screen in front but still be listening to my ipod?
3 is there anyway to completely take the z2 back to factory, this is a used unit and there is places programmed on the nav, also the nav seems to be a bit off, any suggestions on getting it right?
thanks for all the help guys, i really appreciate it. thanks
Posted Jul 31, 2008 · 22:01 UTC#2
1. There is a setting that tells the rear screen to mimic the front screen. Turn that option off.
2. Only 1 audio/video source is allowed at a time.
3.
To return the entire navigation system to the
default or factory settings, initialize the navigation
system in the following order:
1 Turn the ignition switch off.
2 Press the RESET button.
3 Start the engine.
After a few moments, the start-up screen
comes on for a few seconds.
4 Touch and hold the MAP button while the
start-up screen is displayed.
“Clear memory†screen appears.
5 Touch [Clear user information from hard
disk].
❒ This reset operation clears all music data
recorded in the music library. Note that the
cleared data cannot be restored.
6 Touch [Yes].
The user area in the hard disk drive is initialized.
After that, the navigation system restarts.
This would also be the best time to unlock and upgrade your drive to z3, or replace with a preconfigured drive.
garrettoomey
Posted Aug 01, 2008 · 04:36 UTC#3
thanks garrett, could you let me know under what menus the mirror option is located? Look for a while and couldnt seem to locate it. also is there anything that can be done about keeping the ipod buttons on the ipod working rather than through the head unit? thanks
Posted Aug 01, 2008 · 13:31 UTC#4
Selecting the video for “Rear displayâ€
You can choose either to show the same image
as the front screen or to show the selected
source on the “Rear displayâ€.
1 Press the AV button to switch Audio operation
screen.
2 Touch the source icon and then touch
[REAR SCREEN].
Each touch of [REAR SCREEN] changes the
settings as follows:
• MIRROR — The video on the front screen
of the navigation unit is output to the “Rear
displayâ€
• DVD — The video and sound of the DVDs
are output to the “Rear displayâ€
• AV — The video and sound of the AV
INPUT are output to the “Rear displayâ€
❒ When MIRROR is selected, the following
restrictions are applied to “Rear displayâ€.
— When the TV tuner is connected with AVBUS,
its “Video image†cannot be output.
(Connect the TV tuner’s rear output to “Rear
display†directly.)
— When selecting [Rear View] in the map
display, nothing is displayed.
— All sounds cannot be output for “Rear displayâ€.
— There is no picture on “Rear display†while
[Picture Adjust] for [back-Camera] is carried
out.
There is an iPod trick to use the ipod instead of onscreen, but I don't recall it. Give a quick search in the forum.
