where do you have your gps antenna mounted?
By binmop · Jul 31, 2008in General💬 11 posts👁️ 1,755 views
Posted Jul 31, 2008 · 22:35 UTC#1
so ive read through a couple of threads about their navigation not being accurate and im afraid that i should relocate mine, should it be in the middle of the car ? becuause mine is on the top right (passenger) side of the windshield.
note- i dont my have map disc yet so my navigation is not working.
Posted Aug 01, 2008 · 01:54 UTC#2
It shouldn't matter if it's on the right left or middle of your car as long as the antenna has a clear veiw of the sky. Two feet either way won't make that much difference!
Posted Aug 01, 2008 · 02:47 UTC#3
good info thanks
Posted Aug 04, 2008 · 00:42 UTC#4
I have mine mounted right in the center of my dash. It seems to work perfectly fine for me and I never had any problems with where I mounted it.
Posted Aug 12, 2008 · 03:06 UTC#5
Mine is mounted in the middle of the roof in the back. I ran it under the weather stripping into the trunk, then through to the cab and under the passenger seat where the hideaway unit is.
Posted Aug 13, 2008 · 19:25 UTC#6
mine is mounting on the back of trunk below the window. I think i need to relocate as I lose connection on cloudy days...
Posted Aug 13, 2008 · 19:54 UTC#7
i had an installer put it under hide it under the dash... I don't have the best connection but its not terrible. The XM and HD radio have terrible signal tho
Posted Aug 14, 2008 · 06:13 UTC#8
Mines on the center of my dash with no issues out of any of my antennas.
Posted Aug 18, 2008 · 00:42 UTC#9
did u not put it on the dash in the corner because u wanted a cleaner install? should i put my where behind the dash? i have no space in that area probably.
Posted Aug 18, 2008 · 01:35 UTC#10
Mines in the dead center and the wires are coming out of my defroster vents.
They are noticeably but dont necessarily look bad.
Posted Aug 18, 2008 · 03:50 UTC#11
mine is mounted under the dashboard. i havent had any problems with mine at all...with the d3 or the f90
