Nav not working
By SMIGRATOR · Aug 25, 2006in Problems/Troubleshooting💬 9 posts👁️ 1,940 views
Posted Aug 25, 2006 · 19:35 UTC#1
I hooked up the n3 and it worked fine and then i removed the gps antenna and now it wont move it just stays in one spot while driving down the road. any help would be great.
Posted Aug 25, 2006 · 20:08 UTC#2
Without the GPS Antenna it probably doesn't any GPS reception.
Put the GPS antenna back and see what happens.
Posted Aug 25, 2006 · 22:18 UTC#3
I only had the antenna off for 1 minute, then i shut the truck off and now the only thing it does is say put in the right disc and has a black screen, i cant get anything to work at all on the screen
Posted Aug 25, 2006 · 22:30 UTC#4
Have you tried resetting your unit?
Posted Aug 25, 2006 · 23:02 UTC#5
How do you do this?
Posted Aug 25, 2006 · 23:10 UTC#6
There will be a little recessed button somewhere on the face of your unit.
You need to press that with something small like a pencil or really small screwdriver.
Check your owners manual for the location of the reset button.
Posted Aug 26, 2006 · 01:33 UTC#7
I reset the system and it is still doing the same thing.
Posted Aug 26, 2006 · 04:44 UTC#8
Drive a little bit. After you reset it, it's not going to "update" it's self unless it detects motion.
Posted Aug 28, 2006 · 20:31 UTC#9
did you check your antenna cable for kinks/knicks and of course, is it reattached? also on settings/hardware settings, you can see if your gps is receiving a signal
