I can not figure out how to manually add a phonebook to the D3 and CD-BTB200. I have the iPhone 3G which doesn't import the phonebook. I am willing to manually enter my entire phonebook, but I can't seem to figure it out.
Help!!!
Help!!!
Thats because its not possible.
although you can typen in the numbers for your 6 presets. You can not rename them so it will just be the phone numbers, but you can at least enter then in for quick reference.
it worked with my Blackberry Curve (T-Mobile) disconnect the your phone's bluetooth connection with the radio.....navigate to the BT-Tel function screen.....the transfer phonebook option should be greyed out...now use your PHONE's bluetooth control to transfer address book...the radio will accept the connection seemlessly and your info will be transfered.....VERY counter-intuitive...BUT it works....GL!!!
Yes, but the iPhone 3G does not have a transfer address capability like the BlackBerry
