Hd1bt upgrade and questions
By paxtond · Aug 05, 2008in General💬 8 posts👁️ 1,714 views
Posted Aug 05, 2008 · 18:04 UTC#1
hi all.
just joined up here and looking for some advice.
ive just ordered a hd1bt nav unit, i think this is the euro version of the z1
anyways i was wondering if there are any guides and images for upgrading these the same as the usa versions.
my next question is video out put. i know the unit is dual zone but i was wondering if i could output the nav to a 2nd screen and have my av source displayed on my avic screen.
in my current car the double din slot sits to low and its hard to see when driving so i want to put nav up on a higher munted screen
cheers
Posted Aug 06, 2008 · 17:19 UTC#2
no one have any info on these
Posted Aug 06, 2008 · 18:24 UTC#3
From my understanding, the units are identical. Don't wuote me, but I think the only differences are the updates, that are available from Pioneer.co.uk....
As in, I think you can just use the images that are posted here to get your unit to a Z2/3, and just update the CDDA database.
http://www.pioneer.co.uk/uk/content/sup ... HD1BT.html
Posted Aug 07, 2008 · 09:00 UTC#4
hi all.
cheers
There's obviously a number of differences between the Z1 and the HD1BT, as discussed before in this forum. The radiotuner part is completely different, the HD1BT has a different frequency grid and RDS. In addition, obviously, the map database is different. Finaly, also the DVD region code is different...
There's also at least some differences in the firmware, as you can bypass the European units by simply connecting the handbrake input to ground ( and no additional messing around).
So in short, you cannot use the Z1/Z3 software images on the HD1/HD3 !
Posted Aug 07, 2008 · 17:06 UTC#5
thats not what i asked.
what i wanted to know is, are the uk images avalible and is the upgrade process the same as the z3
Posted Aug 07, 2008 · 17:16 UTC#6
I stand corrected...
I would think the process would be the same... I hadn't seen the Euro images posted here.
http://www.pioneer.co.uk/uk/content/sup ... tware.html
Posted Aug 07, 2008 · 17:27 UTC#7
No
Posted Apr 12, 2009 · 00:46 UTC#8
I have sucessfully updated a HD1BT to HD3-II HD3-2 firmware software. I bought a HD3-II and a HD1BT and followed the instructions on this forum for Z1 - Z3 upgrade. I used a Toshiba MK6034GAX 60GB disk with enlarged music partition. Will try Toshiba MK8032GAX 80GB disk soon (1-2 weeks).
