On the f-900bt the vehicle on the screen travels left to right. Is there a way to make it go in the direction you are actually traveling as in most navigation units. Has any one else experienced this problem? ![]()
Posted Aug 07, 2008 · 19:28 UTC#1
you can change it in 3d mode, you tap the screen and a control screen will come up that you can adjust the view. but in 2d its stuck that way
Which i think sux aZZ ..
also miss from the D3 where you could choose from muliti routes .. now it picks and hope it's the way you want to go..
