Very frustrating....any thoughts?? ![]()
HELP!!!****Can't get iPhone 3G phonebook to sync***
You can't. You can enter 6 numbers manually, thats it.
Yea not compatible with the bluetooth options for any of the D, Z, or N series units. Have to go with an F series if you want full iphone compatibility.
yeah the avic bluetooth completely fails with the Samsung I760, the new phones are so advanced the avic bluetooth just fails.
had the connection drop problem did this...
with my Blackberry Curve (T-Mobile) disconnect the your phone's bluetooth connection with the radio.....navigate to the BT-Tel function screen.....the transfer phonebook option should be greyed out...now use your PHONE's bluetooth control to transfer address book...the radio will accept the connection seemlessly and your info will be transfered.....VERY counter-intuitive...BUT it works....GL!!!
Yes, but iPhone 3G does not have an address transfer capability like the BlackBerry
how about having your 3g iphone charge?? i know the 3g lost the firewire, so how do we get it to charge?
Hi.
It is admits the Iphone becherscht not the necessary Bluetooth Protokol. But it becomes possible possible with coming soon iBlueNova. Sorry for my bad English. ![]()
Best regards
To clarify what the above member was trying to convey. iBlueNova is a BT application for Jailbroken iPhones that will allow the transfer of files over BT. It was formally called iBluetooth and apparently will be available as a 15 day trial. There is no info if the phonebook will be able to be transferred from the phone to be used with the unit but this is a possibility and a start in the right direction. Unfortunately it appears to be in beta and not quite available to the public at this time. Check Cydia periodically for updates.
Exactly, thanks!
