1) Is the SD card reader on the 900BT limited to 2GB?
2) On 2008 STI, where did you guys tap the reverse wire?
Thanks,
Mike
Thanks,
Mike
1 - no. The manual says it's a maximum of 8GB. But there are people who are using a 16GB card in it. Most likely the limit os 32GB, but 8GB was pretty much the largest size SD card available at the time the unit was made.
2 - You can just tap into the power wire going into one of the reverse bulbs at your tail lights.
