problem getting image on disk
By fraalan · Aug 08, 2008in Hacks/Mods💬 8 posts👁️ 1,194 views
Posted Aug 08, 2008 · 14:41 UTC#1
I followed the instructions on the pdf file to a tee.
And it seems like the z3 doesnnt want to accept the hard drive.
I find it odd that you only restore 2 of the 4 partitions per the instructions.
Wouldnt you want to restore all 4 partitions making the audio library the largest?
Thanks for any input, and no I dont want to buy a preloaded drive.
Posted Aug 08, 2008 · 14:46 UTC#2
If you are refering to my upgrade pdf, it was designed to only upgrade maps and software. This was to save the library and addressbook.
If you are wanting to upgrade the whole disk, then you will want to restore all 4 partitions + the MBR partition in one swoop.
Check the sticky:
http://www.avic411.com/forum/viewtopic.php?t=9446
Are you using a stock drive that you unlocked, or are you using a new toshiba 40, 60, or 80 gb drive?
If you have a NEW drive, then you will need to do a whole install (see sticky above). The pdf states in the assumptions that you have a working Z1, Z2 or Z3 drive to use the upgrade pdf.
Let us know.
Posted Aug 08, 2008 · 22:06 UTC#3
i figured thats what I did wrong.
I am having issues with the mhdd floppy
all i get is a blinking cursor when I boot to a:
shift f3 does nada
thanks for you help
Posted Aug 08, 2008 · 23:10 UTC#4
Try typing "MHDD" at the prompt.
Posted Aug 08, 2008 · 23:32 UTC#5
thats the problem, i cant get to a command prompt.
I have a second pc and get the same issue.
I build my own pc's so I can handle this,,, i think. lol
is there another program?
Posted Aug 09, 2008 · 00:27 UTC#6
darn usb keyboards
I am good to go
thanks all
Posted Aug 09, 2008 · 02:02 UTC#7
So were you able to run it (MHDD)?
And, if so, were you able to remove security on your drive?
Posted Aug 09, 2008 · 03:56 UTC#8
yeah i dug out an old keyboard and i am loading the image now.
no problemo
