Avic n2 installation -Factory dvd entertainment unit
By Babybusa · Aug 27, 2006in General💬 3 posts👁️ 1,075 views
Posted Aug 27, 2006 · 21:46 UTC#1
Just bought a 04 Yukon Denali w/ a factory dvd entertaimment system. Would I be able to install my avic N2 into the dash and still be able to watch the rear dvd entertainment without any compromise?
Posted Aug 27, 2006 · 23:44 UTC#2
To my knowledge it's not possible to integrate the factory flipdowns in gm vehicles.
Posted Sep 06, 2007 · 22:47 UTC#3
I just did it on my 05 Yukon XL w Bose system
All you need is a GMOS-04 interface to retain your onstar and to turn on the bose amp and dvd system. The headphones and player will work as normal.
Now if you want the Video and Audio out to your headunit thats a different story and it is also doable but requires finding the correct leads off the dvd player and running rca's from your headliner to your headunit/brain. I also did this and the leads for my unit were darkk blue for video and brown and black for my audio along with a common ground going to a shielded wire that is pretty easy to spot. (sorry I did not write down the pin locations on the back of the player).
I hope that helps you.
