Been lurking since yesterday when I bought my AVIC-F700BT. So I thought I'd offer my fix for it. Should make for a nice first post. Now this fix isn't 100%, or gonna be the solution for everyone.
The way I fixed mine is to use the ground in the wiring harness in my truck (99' s10) Run a pair of wires, preferably between 10ga and 14g, from the battery to the back of your unit.
**Disclaimer**
Make sure you use the appropriate fuse when you come off the battery. Do you self a favor and spend a few extra bucks here, you will thank me later. No fuse=bad. Such as shorting your electrical system (this includes your ecu, which is your cars computer) Wires shorting out, causing fires. Don't get me wrong. Its not a big deal, its safe as long as you do it properly. Not a whole lot different than wiring a system in your car.
One of those wires is going to go to the switch(toggle, push button, rocker, etc.) Doesn't matter what kind, whatever you think will look good in your car. Just make sure its a on/off, not momentary. Then from the switch to the red wire. This is your switch/accessory wire. This will allow you to keep the radio on. So that it doesn't reboot every time you start the car. The other wire is going to directly to the yellow wire. This is your constant/memory. The reason for this is you'll retain your settings. Like am/fm stations, time, all that stuff. Now you can turn the switch on when you get in your car for the first time that day, wait for it to boot, and go about your business. That way when your out running around you can stop and get gas, drinks, drop kids/movies off, etc. You won't have to wait for it to reboot. Then at night turn the switch off. When you park the car for long periods of time you you can go to the source list and hit the off button, or you can just turn the switch off. Depending on your battery and your vehicles charging system. I would guess you could leave the switch on, with the radio itself "off" for probably around 8-12 hrs. And still be able to start your car. Now depending on what kind of battery you have will determine how long you can leave the radio on. I've got a yellow top optima which is a gel battery. This will allow you to leave it on longer.
Don't quote me on these times but with my optima I can go quite a while without having to worry about it. With this you could get a battery cutoff as well. This would replace the switch. You wouldn't need the switch because the battery cutoff would stop sending power somewhere around 11.5 volts. Leaving you with enough power to start your vehicle. You'd need 2 fuses. Once for each wire running to the radio or put the battery cutoff after the fuse on the line for the red wire (switch/accessory) You don't want the battery cutoff to cut the power to the yellow wire (constant/memory) This would cause you to loose your settings. You could continue to use the switch, and the cutoff. The cutoff would just be a safety device to make sure you wouldn't have a dead battery unexpectedly.
You may want to run a new ground as well. You can find these all over the place. The shorter the better. Make sure to use the same size ground as power wire. My truck has a good ground in the factory harness, but other vehicles may not. I know When I had my 97' Nissan Hardbody (pick up) They had bad grounds in the harness. The factory radio was fine, but aftermarket radios wouldn't work with the factory ground.
I wish I could offer a more permanent/easier/faster/ solution to this problem. But this is what I'm using till Pioneer does there job to fix all these crazy problems. Spending a grand for something, only for it not to work is unacceptable. Before you start on how Pioneer can't or might not be able to do anything bout the boot up. Yes I did read the post about how they can't. I hope this helps. Not perfect, but its better than nothing
