I installed my D3 yesterday. If I try to type an address it searches only OR,WA and one more. I live in MN. It knows where I am on the screen but wont let me search. HELP??
Posted Aug 10, 2008 · 00:25 UTC#1
Are you using the correct map disk? Minnesota is dead center in the US, and the disks are separated into east and west. Maybe the other disk will work correctly.
You have to put in the number that corresponds to your area/state. Also put in the map disc that has your state highlighted on the front fo the disk. For example im in louisiana so i used the east disk, and when i search I use area #7, I also travel to florida alot which is area #10
