Sound cutting out at higher volumes...02' Tahoe...HELP!
By jroth142 · Aug 10, 2008in Problems/Troubleshooting💬 2 posts👁️ 609 views
Posted Aug 10, 2008 · 13:28 UTC#1
Hey guys, in the process of trying to install my D3 from my old car (used the unit for about 4 months total) into my 02' tahoe. Just hooked connections up to make sure everything was working properly and noticed the problem. Works great at lower volumes but if I turn it up or turn the EQ gains up the sound just quits altogether. The unit still has power, just no sound. If I turn it off and back on the sound will work again until the volume is turned up.
My tahoe does not have the BOSE system so I'm not using any amp interface, just connecting wires directly to the harness. I believe its just the upgraded DELCO system, 9 speakers total I think.
Can someone help me out?? Thanks
Posted Aug 10, 2008 · 15:41 UTC#2
It also seems to cut out if I just change the key position when the truck is off, or actually start it. I have no clue what's going on! :(
