Innovatek DVD changer with IP Bus???
By sportsfan21 · Aug 28, 2006in General💬 9 posts👁️ 4,921 views
Posted Aug 28, 2006 · 13:22 UTC#1
http://www.mp3playerstore.com/stuff_you ... P-6808.htm
Does anyone know if this will actually work? It has an IP Bus control and, correct me if I'm wrong, can't you use the RCA inputs on the D2 but still control it from the headunit?
Its just wierd because I've never seen any other product besides Pioneers have IP bus control.
Any thought/comments?
Posted Aug 28, 2006 · 15:07 UTC#2
Wow, that's weird to see something non-Pioneer with IP-Bus.
I would guess that it should work.
YES you can use RCA inputs on the D2 and control it from the head unit. In the setup you can see where you can change the RCA inputs between AV and M-DVD (or something like that). The latter setting enables the video input when the source is M-DVD.
Posted Aug 28, 2006 · 18:41 UTC#3
I would guess that it won't work in IP bus mode. All of Pioneer's dvd changers also require an AV bus cable because that cable passes some of the control information from the touchscreen back to the changer. My guess is that you would have to run it in standalone mode, run it in through the AV input, and control the dvds with that remote.
Posted Aug 28, 2006 · 19:18 UTC#4
I really think it should work. The manual says this:
Touch “AV INPUT” in the SETUP menu.
Each touch of the “AV INPUT” changes the
settings as follows:
• OFF — No video component is connected
• VIDEO — External video component
• M-DVD — DVD player connected with RCA
cable
When a DVD player is connected with an AVBUS
cable, do not select “M-DVD” or else no
picture is displayed even if you select S-DVD.
I have tried it, and when set to M-DVD, the M-DVD function in the AV Menu is still dimmed out as though it's expecting an IP-Bus device. This tells me that an IP-Bus device mapped to M-DVD can still send its video over an RCA cable if the AV INPUT is set to M-DVD.
Although worst case scenario would be you have to chop up an AV-Bus cable and splice a composite RCA video cable into it to make it work, but I really think it won't be necessary.
Posted Aug 28, 2006 · 23:34 UTC#5
Hmm... I also read what Shawn did in the manual and I think it will work.
I'll just have to buy it and see.. I'll let you guys know.
Posted Feb 09, 2007 · 23:52 UTC#6
Has anyone tried this out yet? It would be interesting to see if this works.
Posted Feb 10, 2007 · 04:20 UTC#7
As far as I know no one has bought this yet. Even though its been 5 months since I started this post :lol:
Posted Feb 10, 2007 · 04:25 UTC#8
That's ok in that 5 months, I still haven't been able to get on that website to even look at the thing.
Posted Feb 10, 2007 · 11:51 UTC#9
Is that because it looks like an Alpine? Or just because it looks ghetto fabulous?
