I would really appreciate any help on this issue as my gps is pretty much unusable right now.
I upgraded my Z2 to a Z3 and now my gps does not track correctly. The direction indicator that points in the direction of travel will drift and even change all the way so that it is pointing backwards. The position indicator also drifts and hangs up in places.
I don't really understand why the computer can't figure out the direction of travel after taking samples and trying to learn, I am pretty sure that a garmin does this.
Things I have tried to do to fix the issue :
I have reset tall of the hardware several times (only momentarily fixes the problem)
I have adjusted my position and direction manually on the screen (seems to fix it longer than resetting the calibration)
Removed and re-installed the hard drive (no real effect)
Things I might consider a problem :
could it be a grounding issue? I never had this problem when it was still a Z2.
Please help, any help is appreciated.
