I recently installed my Pioneer-reconditioned Z2 in my 2009 Toyota Matrix S. Installed XM, iPod and Bluetooth as well. All was fine.
Today I performed "bypass surgery," as it were. For a time, it worked great. I managed to play a DVD with the parking brake disengaged and the car in reverse.
Then the trouble started. Before I set it back in, I tested it and saw that everything worked. Then I bolted it back and put the trim on, turned the car on, and got no power. Not even the black starting screen.
For the past 3 hours, I've been quadruple- and quintuple-checking my connections, and everything seems okay. Ground wires are indeed grounded. Red wire gets 12 volts, according to my multimeter. Fuses look okay.
Two things, though:
- The yellow wire does not get 12 volts. It usually flutters around 0.5, even when the car's on. (I have no idea -- how much voltage is it supposed to get?)
- Out of curiosity, I plugged my factory radio back in, and it didn't turn on.
So, I don't think my problem lies in my wires or harness. What am I missing? Did I sever a wire behind the harness? Should I pop the factory radio back in and go to my Toyota dealer with my tail between my legs for some free warranty work? Any help would be much appreciated, and many thanks in advance.
