My cell phone AT&T Tilt made by HTC doesnt connect with my D3 just installed last night, thumbs up to the bypass threads worked perfect
att tilt by htc doesnt connect with d3
You will have to download a program called jetware and install it on your phone. It is at www.jetwaremobile.com I installed it on my phone and my tilt works perfect with the D3 now.
Where does this program need to be installed in the phone?
Russell
what you will need to do is go to the web site on your phone. then download to the memory card. then go to the file where you downloaded it and click on it and install it. then try to repair the bluetooth and it will work.
now the you would have to buy it after 30 days. but i think that i found is a hack for it. now after you pair it. turn your car off and then get your phone and uninstall the program and it works with the d3 and the bluetooth on it. but just one note i do have the ftp krazer bluetooth hack still installed on my phone. now i think that its code has been changed some how by that jet program and it works fine with it.
so have you tried it yet and did it work like i said it would. i have the same phone but for sprint and it the mogul or tytin 1
