Mute/Attenuate Music during nav guidance?
By elcid · Aug 13, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,382 views
Posted Aug 13, 2008 · 15:33 UTC#1
Supposedly you can make the music not mute when the navigation voice is playing (Operation Manual: Page 144) and I know you could do this on the N2 that I had previously in a different car. The problem is, now that option is blacked out on the settings menu. Is this because I removed the mute wire to do the bypass? If so, then I'll have to reconnect a wire to that post on the harness, but where in the vehicle would that go since I have no mute wire on the vehicle harness (that I'm aware of). Any ideas or maybe did I just not fill out some setting?
Posted Aug 13, 2008 · 16:01 UTC#2
It's blacked out because you have the AV source on. Turn it off and go back to settings.
Posted Aug 13, 2008 · 18:03 UTC#3
I'll give that a shot. Does that feature only work with FM/AM and CD then?
Posted Aug 13, 2008 · 18:11 UTC#4
any av source that is playing will be affected if you change the option, fm, am, sirius, xm, ipod, cd, sd, whatever. but like bleargh said, make sure that your av is off in order to change the setting
Posted Aug 13, 2008 · 18:17 UTC#5
It works with all AV sources.
Posted Aug 13, 2008 · 19:13 UTC#6
And why exactly do I have to turn off the AV source before making changes like this?
Makes no sense...
Posted Aug 13, 2008 · 19:16 UTC#7
the same reason theres unneccessary blue boxes on the map...its just how it is :roll:
Posted Aug 13, 2008 · 19:27 UTC#8
Makes no sense...
Why does changing certain settings on your computer require a restart for the changes to take effect? It just does.
