how do i check if unit is working?
By tdirlmeier · Aug 14, 2008in Problems/Troubleshooting💬 2 posts👁️ 823 views
Posted Aug 14, 2008 · 21:14 UTC#1
Ok, so I just bought a used AVIC-N3 unit and the only thing missing is the 30 pin cable so I'm wondering if there is a way to test the unit without the cable that links the headunit to the hideaway unit? All I should need to do is hook up the yellow power wire and the red ACC wire to a 12 volt system and then hook up the ground. Or do I need to have the 30 pin cable? Please help. i need to know if the unit is working before I order the 30 pin cable and so i can get my money back if it does not work.
Posted Aug 14, 2008 · 23:26 UTC#2
You have to have that cable connected to get anything out of the head unit.
